Home Forum Ask A Member Timing Big Twin/RD Rope Starter
  • #9474
      Does anyone have the instructions or page number handy for timing the starters with compression relief on these motors? I glanced thru the 10th edition but couldn’t find it. I know it’s in there somewhere.
      #72908
        would loosening the linkage help….page 316 timing the starters ??? question ambiguous to me anyway
        #72910
          The compression relief is "timed" by using the correct rope length. When recoiled, the arm should be in the position shown. As soon as you begin to pull the rope, the arm moves outward in the scroll, opening the valves.
          #72911
            Thanks Frank. That’s exactly what I was looking for.
            Now the valve gap?
            #72912
              Valve clearance is .018"-.025". Adjust with motor cold and rope recoiled. Loosen locknut and turn screw in till it just touches valve stem, then back it out one half turn which will give approx .025". Check with feeler gauge.
              BTW, this stuff is given in the powerhead section of my service manual.
              #72914
                Found it! Pages 316-317 in the 10th edition.
