Home Forum Ask A Member timing setup on johnson jw-10
  • #186288
    laville44
      how do you set up timing on jw-10 and what is #1 #2 cylinder
      #186289
        Noting to set on the timing, except to time the breaker points to open at the correct time as the flywheel magnets pass by the coils. You can get them “good enough” by setting the points gap to 0.020″. Or you can get them perfect by using the special tools timing fixture. richardsoutboardtools.com makes reproduction timing fixtures, if interested.
        EDIT: #1 coil is the one closest to the front of the motor (forward)
        • This reply was modified 6 years, 4 months ago by frankr.
        #186291
        RICHARD A. WHITE
          pssst, that tool is in stock 🙂
          classicomctools@gmail.com
          #186314
          donsmarine
            or you can use a timing light and really get them equal, increasing clearance moves mark to the right
            #186360
              http://www.youtube.com/watch?v=ga1Cjymj6ms&feature=youtu.be
              this works also a small bulb and battery wired in series can act as a test meter
              #186375
              donsmarine
                I think checking the timing with engine running, things wiggle, is more accurate especially when the armature plate is loose. Pulling flywheel more than once can a pain thou.
