Home Forum Ask A Member TN-27
  • #264630
    russ
      Working on this motor and found some type of resin or goop.When I pulled the tank off this was on the bottom side of it and on the inside of flywheel and all over the coils and mag plate.It was dry and I could scrape some off. Is it possible that someone was trying to seal lamination on coils? No big cracks that i can see.Lots of goop where wires go into coils and on the front side of coils. These look original. Nothing inside of coils that can leak out? Thanks Russ……..
      #264674
      reivertom
        Maybe somebody used a type of grease on the cam lobe or they sprayed some lube up there and it dried up. It’s hard telling what Bubba might do to a motor in all those years. The only thing under there with lube, is oil on the piece of felt that lubes the breaker point cam. I guess somebody could have gotten carried away. The other possibility could be the upper crank seal under the plate could be leaking a little over time.
