Home Forum Ask A Member Tn-27 prop shaft seal
  • #2496
    clemg
      The original part # is 41-62. I order one with the new part# 321788. The new seal is has a different depth size than original. It is about half the depth than original. Any ideas?
      #23604
        That is the correct replacement seal. You can use the thinness to an advantage by installing it at a different depth so it rides on an un-worn area of the shaft. Or, better yet, use two of them if there is enough room. Install the inner one lip toward the oil and the outer one lip toward the water.
        #23620
        clemg
          Thanks for your help!
