Home Forum Ask A Member tools making life simpler
  • #225762
      I got tired of guessing how deep to screw in the bolts on the flywheel (harmonic balancer puller) to make certain I had a good grip and more important to make certain the length of the bolts were the same so as not to tilt the puller one side or the other
      If you are new at working oldies and pulling flywheels just insert the bolts in each of three legs over a thick washer and at the other end, install nylon lock nuts at the same length on each bolt (I use 4 inch stainless bolts . 1/2 inch is ok see picture
      the nylon lock nuts will stay in place , sit squarely on the flywheel and ensure you have reach sufficient depth to prevent stripping the threads while keeping things level top side
      Another great tool is a split blade screw driver to hold on to those pesky screws that fall down the engine housing .
      • This topic was modified 5 years, 2 months ago by JACQUES.
      #225768
        Better idea than the masking tape I put on my bolts.
        I still use my harmonic balancer puller on small outboards,
        but the OMC puller is slick as it has “shoulder bolts” that
        can only screw in so far.
          Amen on the screwdriver. Here is another style that is worth its weight in gold for working on little stuff like magnetos. Shown is mine holding that little screw that holds the coil & condenser wires to OMC breaker points.. I bought mine from Snap-On in 1954 and it is one of the most-used tools in my toolbox.
          https://www.mcmaster.com/screw-holding-screwdrivers/tight-clearance-screw-starters-7/
          #225780
            I could have used one of those screwdrivers today. I used to have
            a magnetic screwdriver but that wouldn’t had done much good
            on aluminum screws. The screw I was trying to start while looking
            under the motor only fell to the ground three times before I
            finally got it in, lol.
              Just a caution…..the split blade screwdriver is not for torquing it is for only for engaging the bolts in place it is also convinient of carb bolts (5)
              of course it is only for slotted head bolts:-)
              https://www.amazon.ca/SK234-Slotted-Screw-Holding-Screwdriver-3-Piece/dp/B0002RIA3K/ref=sr_1_3?dchild=1&keywords=klein+slotted+screwdriver&qid=1608682046&sr=8-3
              #225782
                Just a word of caution…..the split blade screwdriver is not for torquing it is for only for engaging the bolts in place it is also convinient of carb bolts (5)
                #225783
                  they do make them for phillips.
                  I use a short slotted one for fixed jets on my mercury’s.
                  #225787
                  swamp yankee
                    I couldn’t get anything to pull mine off the jw-22, had to improvise
                    #225791
                      #225806
                        I’ve got that red pick…… use it daily!
