Home › Forum › Ask A Member › tools making life simpler
JACQUES wrote: Just a word of caution…..the split blade screwdriver is not for torquing it is for only for engaging the bolts in place it is also convinient of carb bolts (5) of course it is only for slotted head bolts:-) https://www.amazon.ca/SK234-Slotted-Screw-Holding-Screwdriver-3-Piece/dp/B0002RIA3K/ref=sr_1_3?dchild=1&keywords=klein+slotted+screwdriver&qid=1608682046&sr=8-3
This link goes to Amazon.com. Have you tried Amazon.ca for us Northerners which will be in CAN dollars?
yes …as ususal I ordered a 12 incher then…. found my old one deep in the tool box so I cancelled the new one. 🙂
A tool that i find useful for many things other than what it was designed for is a cotter pin puller
sydinnj wrote: A tool that i find useful for many things other than what it was designed for is a cotter pin puller
You mean there’s a tool to pull cotter pins? I always have used my “side cutters”, or whatever they’re called.
If I had a hammer..
I just ordered a set of the screwdrivers.
OK
