Home Forum Ask A Member Tramsom Bolts and pads removal
  • #233663
    ERROL STILLINGS
      I have two Evinrude Zephyrs-one is junk for parts, and the other is somewhat better. Anyhow, trying to figure out how to remove the transom pads from the transom bolts, so I can exchange
      the good bolts/pads from the junk motor to the better motor. Am I missing something – is there a trick to it, or something simple that I am missing?
      #233669
        they re likely crimped so a pry bar should do
        to install them without the tool ( see OUTBOARDER) I have used the suggested method here on AOMCI
        center drill and tap the shaft install the cup with an appropriate bolt with a flat head or grounded head to fit in the cup cavity .
        use some lock-tite to secure the hard to tighten new bolt
        #233670
        ERROL STILLINGS
          Thanks, Crosbyman. I don’t have “the tool”, and will follow your advice, and go after it.
