So I have a couple of motors but namely my favorite Johnson rd-19 has a busted transom clamp thumb screw that I have finally gotten around to fixing. I’ve tapped out the old pin that holds the thumb clamp to the threaded screw but my question is,
what do you use to replace the pin that holds the two pieces together?
I know the original pin is aluminum and 3/16″ diameter but could I use the 3/16″ brass rod that I already have as a suitable replacement??
First time doing this so any pointers are appreciated.
Thanks
