Home Forum Ask A Member Tune up
  • #253039
    Donald Wilkinson
      1949  10hp  how to set point.
      #253043
        very easy… go max openning on the points and set for .020 is the  usual  fast method
        just keep those point  clean  clean  clean
        as a member  of AOMCI
        you  can download yourself a copy if the johnsnon service manual  !!     se pages 38-42 in the red book
        go to MEMEBERS ONLY tab…. select INNER SANCTUM….go down to LIBRARY…find GARRY SPENCER’S <b>drop box</b> … open it then go all the way downn to the RED BOOK …. down load it to your PC
        you can get it printed and bound at a local print shop I did mine in 2 binders)
        • This reply was modified 4 years, 2 months ago by JACQUES.
