Home Forum Ask A Member unhooking the pins for 9.5 hp kill switch
  • #205105
      I need to resolder some new wires on the push button kill switch but the plastic connector ends is giving me problems
      is there an easy way to slide out the metal pins inside the mating plastic connectors on the kill wires …..connecting to the mag plate points ..
      tricky little devils but If I can slide out the pins I’ll resolder the new wires to replaced the old ones that are all cracked and brittle
      if impossible I may by a 2 wire connector….but I like the old ones that mate and lock
      thanks
      #205138
        well… solved the problem with flat blade tipped male female connectors …
        • This reply was modified 5 years, 8 months ago by JACQUES.
