Home Forum Ask A Member Unknown gas cap
  • #6403
    opposedtwin
      Any idea what motor this gas cap fits? Should be from a Johnson S maybe. It’s been a loooooong time…… 😮
      melugin
        Evinrude rowboat motor. Early Johnsons also had the oil measuring cup, but with a different cap.
        #53455
        PM T2
          Is the cap aluminum or brass?
          Aluminum means it is likely off a 1922 evinrude model K. I believe all other Evinrude rowboat motors used brass caps.
          This cap will also fit the Model N Sportwin, model LA/LB Big Twin, model R Fastwin, heck I think it will fit all Evinrude motors from 1914 to 1928-29. It will even fit the 1930 Lockwood ace that used the Evinrude Fleetwin tank.
          Edit – it will fit those tanks, some of those motors need to have have vent screw on them to be 100% correct…..
          Hope this helps.
          best,
          PM T2
          #53456
          opposedtwin
            It’s aluminum.
            #53459
              could be a Clark Troller.
              #53463
              melugin
                I stand corrected. It looked like it from here.
                #53467
                PM T2
                  Roger, you’re not wrong, it does fit Evinrude rowboat motors.
                  And I should amend my original post to say it "could" be off an Evnirude Model K, instead of saying "likely"
                  Best,
                  PM T2
                  #53474
                  kees
                    International Member
                    quote opposedtwin:
                    It’s aluminum.
                    is it for sale ?
                    if so , let me know
