Home › Forum › Ask A Member › Upgrade Control Box?
- This topic has 8 replies, 5 voices, and was last updated 3 years, 11 months ago by
billw.
April 4, 2022 at 11:15 am #257455
I have a 62 Mercury 700 and when I was at a boat shop last year I inquired about what it would take to upgrade the controls to a newer model. What I was told is that I needed a “Mercury Mark 1 to Gen 2 Adapter”. I’ve searched high and low for this part with no success, and I’m not even sure if the guy was correct in his terminology or that it could be done at all.
While I like the vintage look of my current control box, it’s getting a bit long in the tooth and I would like to replace it, with the intention of perhaps stripping the old one down and rebuilding and repainting it later.
So is there actually some sort of adapter that would allow me to upgrade my control box?
This topic was modified 3 years, 11 months ago by
ColoradoFourWheeler.
April 4, 2022 at 11:46 am #257463Craig I don’t know the answer to your question. Try sending an email to these guys. They know lots about Mercury and they will help for sure!
http://www.fergusonpoolemarine.com/
dale
April 4, 2022 at 1:48 pm #257467The answer is, use your electrical. then use any merc control you want.
It is full gear shift correct.
April 4, 2022 at 6:15 pm #257476Yes, it’s full gear shift but I don’t know what you mean by “use your electrical”.
April 4, 2022 at 7:03 pm #257477use the key choke and wiring from box to motor.
1 914 310 7086
This reply was modified 3 years, 11 months ago by
DAVID.
April 4, 2022 at 11:10 pm #257492Dave, are you saying that the square mercontrol box can be used with pre 65′ motors?
April 5, 2022 at 7:17 am #257501Yes it can. call me if you want.
1 914 310 7086
April 5, 2022 at 2:21 pm #257529Will do
April 7, 2022 at 5:55 am #257599I believe this is what they were talking about, in your original post, for an adapter. Connects a cowl mounted wiring harness to the newer style, round plug, found on later (but still old by today’s standards)) control boxes.
https://www.ebay.com/itm/272805319103?hash=item3f8476d1bf:g:f0cAAOSwopRYdqYA
