Home Forum Ask A Member Upper crank seal 303804 ’57 Lark Superseded?
  • #5981
    mas
      Hi,
      Just picked up a upper crank seal for my ’57 Lark. The original PN number 303804 was superseded to 321467 in a sealed OMC package…but doesn’t fit. The seal is too small and falls into the recess. Was it packaged wrong or is the superseded number wrong. I have cross referenced with Marine Engines…which shows the 321467 number…but I have found errors on their site too since their conversion.
      Any help?
      Happy Motoring,
      Mas
      #49879
        Must have been packaged wrong? What does the seal measure?
        #49880
        mas
          Looks like 1 3/8 in diameter
          #49881
          mas
            OK…maybe I’m seeing this wrong. Does the seal fit into the upper crank bearing or the crankcase/block?
            #49882
              I suspect you are seeing it wrong. It fits in the bearing shell.
              #49883
              mas
                That is what I began to realize after Chris asked for a measurement. I’m just getting back to my Lark rebuild and it looked like I hadn’t installed the upper seal at a quick glance. The large recess fooled me…thinking it needs to be filled with a seal.
                I think I’m OK
