Home Forum Ask A Member Using evaporust to clean fuel tank
  • #9167
    obnut
      I have a 1957 Johnson ad11 that has a none pressurized fuel tank. Has anyone used the product Evaporust to clean rust out of the tank? If so how well does it work?
      #70753
      jim-moffatt
        It cleans rust but not sludge. You should first make sure all old oil/gas is removed then use the evaporust. It needs to be at 70 deg or higher t o work well.
        #70764
          stones and vibration are pretty good apparently….with a good shake
          #70773
          mike-stroz
            Those water based rust removers work really well if you clan the oil and gas out pretty thoroughly first. I like Metal Rescue myself.
            #70782
            jerryswiss
              I am working on a small tank right now and first I sand blasted it, which works really well on the bottom and sides, but not the top of the tank. Then I filled it up with nuts and bolts and turned it upside down and shook it around. Then wrapped sandpaper around a finger and tried to get the inside top of the tank as best I could.
              To neutralize the rust I use this water-based stuff I get at Wal-Mart called Krud Kutter, comes in an 8 oz bottle, really cheap. I have used this stuff for years, it works great.
              #70790
              amuller
                I agree that you have to get the organic sludge out first, so the rust treatments can get to the tank itself.
                #70791
                obnut
                  Thanks for the info. Tank is empty and all I see is rust.
                  #70794
                    well you have the option of electrolysis… check the web for the proper mixture + some DC current and the rust will be lifted away
                    btw… if you are running non pressurized…have you considered getting a new tank 😉
