Home Forum Ask A Member Variable Pitch Prop, aftermarket kit?
Viewing 10 posts - 1 through 10 (of 21 total)
  • #4055
      I acquired an Evinrude Zephyr which had a adjustable pitch prop
      controlled via cable and lever on the side of the engine.
      I forget the brand name on the control plate… "Vari Prop"
      or something perhaps. Will take photos tomorrow.
      On the control panel it shows the forward speed ranges, but
      also shows reverse. Did this really work?
      Were they a desirable option in the day, or just another fad that
      didn’t pan out?
      melugin
        These offered variable pitch(speeds) and also neutral and reverse. Merely a flash in the pan. Didn’t last long on the market. They even offered them for some of the motors which had gear shift. Due to mostly non-shift motors for their applications, I would venture that products came out in the early fifties. One dealer still had most of his original stock in the early nineties.
        #34946
          • This reply was modified 7 years, 4 months ago by Tubs.
          #34947
            Tubs, that’s the same brand my Zephyr has, but mine has a
            lever more like an old lawnmower throttle.
            It’s Model FP 102.
            Went to take photos, batteries dead. Put in spares, still
            says batteries dead 🙁
            eviltwin
              Interesting. Clever way to convert to FNR for outboards without. I probably would not want to drill holes to mount it in mine, though.
              #34963
                Mine has a band that clamps around the lower unit so I believe
                no holes were drilled on the bottom end, but believe they did
                drill one hole up by the powerhead to attached the control cable
                lever.
                  Took some photos today of my new Evinrude Zephyr
                  with the Flex-Prop conversion. It seems to have good
                  compression, so hopefully it will be a runner some day
                  so I can see the Flex-Prop in action!
                  I’m unable to find any advertisements or information
                  on the Flex-Prop conversion kits.
                  Anyone have literature on these?
                  Thanks.
                  Both photos were "upright" on my computer……
                  What the Heck?
                  david-bartlett
                    Buc,
                    Coolest Zephyr I have ever seen. Looks great.
                    #35021
                      I think our BBS is doing something to rotate the images….
                      When I select "view image" in FireFox, I get a right-side-up image!?
                      #35025
                      eviltwin
                        Ahhhh, Buc your pics show it clamps on. No drilling. Shifter looks good too.
                        Pics were upright on this end.
