Home Forum Ask A Member Vishay caps.
  • #11519
    elgin2
      Do I need to use heat shrink on the leads of these to replace a condenser? Thanx,Mike.
      #84310
      lyks2tinkr
        The way I do it, the lead that goes to the mag plate is bare but a put some heat shrink on the lead that goes to the points.
        #84327
        elgin2
          Okay, thank you.
          #84675
          elgin2
            I`m starting to re-assemble this motor. Does it matter which end goes to the mag plate or the points? Thanx.
            #84680
              No.
              #84682
                http://www.farnell.com/datasheets/26450 … 1540039882
                #84690
                amuller
                  OK, can we simplify this? Which ones do I order and where do I order them from?
                  Alan
                  #84691
                    quote amuller:
                    Digi-Key supplies them but first you will have to know the microfarad (uF) rating of the ones your motor needs.
                    Here are links to 0.10, 0.15, and 0.22 uF caps from Digi-Key. You can choose your country in the top right corner.
                    https://www.digikey.ca/products/en?x=23 … =bc2607-nd
                    https://www.digikey.ca/products/en/capa … =bc2608-nd
                    https://www.digikey.ca/product-detail/e … ND/2260507
                    I ordered some caps and a power supply recently and it arrived in in 24 hours! That’s among the fastest shipping I’ve ever seen in Canada!
