Home Forum Ask A Member Water Pump/Driveshaft Removal Mark 55
  • #239465
    Spinner
      Hello! On a Mark 55, I have removed the impeller, impeller pin and pinion nut. Is it possible to heat the lower body and ‘tap’ out the driveshaft/water pump cartridge? I tried this technique but nothing moved. I don’t want to break anything so I thought I should ask. I had the driveshaft in a vice and was hitting the lower unit with no luck. Thanks in advance.
      #239467
        That is the way.
        #239469
        Pondrocket
        Keymaster
          Some come out easy others will fight until out. Use heat make sure vise is tight to driveshaft. There is a tool for this works most of time as long as you have a good grip with vise. Here is a link to the tool.
          http://www.johnsmcintoshvintagemercuryoutboard.com/Mark50-Mid1960DriveShaft.html
          Travis
          Travis
          #239470
            tool works on easy one pulls the cartridge only out.
            #239471
            Spinner
              Thanks for the replies! I will see if I can muscle it out, if not will go the tool route.
              #248241
              Spinner
                Had to get the tool and it worked great! Took some muscle but it slid out. Thanks for the tips!
