Home Forum Ask A Member water temp gauge kit for 57 Johnson?
  • #11144
    minger1016
      Hello.
      I was researching the possibility of adding a water temperature gauge for my 1957 Johnson 30hp and 18hp. I saw a video where they screwed a sensor into the waterjacket housing of a Johnson outboard that apparently had a "blind" threaded hole with the correct size for a sensor, but that was for a newer motor. I can’t find any information for installing this on older outboards. Is there a way to do it on these older motors? Thank you in advance.
      Mike
      #82577
        There are gauge kits that use a sensor that goes under a head bolt. No drilling required. Research that.
        #82622
          you could set up a wireless BBQ thermometer probe đź’ˇ :geek:
          #82647
          seaflash
            Water Temperature Gauge = No.
            Warning Light for Engine Overheating = Yes
            Easy installation = Yes
            Where to Buy? = Check auction site.
            #82684
            dan-in-tn
              I bought a Heat Chek (kit like pictured) off eBay. My 1957 EV Lark had one on it & I wanted a kit to see what it was about. You can look on MarineEngine.com in the J/E Accessories Parts book section. Starting in 1972 they had one kind of sensor (still available) & by 1976 had changed to the other style which is kinda universal. Has a bracket that mounts the sensor up against the head/block depending on application.
              The problem comes with the gauges. They are too slow to react to save your motor in most cases. That & unless you drive with one eye on them all the time you don’t notice it climbing. An overheat is usually a quick thing & can be catastrophic! That is why later model engines have gone to horns & speed limiting systems to get the operators attention. JMHO
              Dan in TN
              #82729
              minger1016
                Thank you all for your help. I will check out those options.
                Mike
                #82733
                  Guess I’ve always had a little different view on the modern-day overheat horn/limiting systems. By the time those go off, your motor is already in overheat mode. I’ve always relied on a gauge to help monitor engine temp and on the few occasions I’ve come close to an overheat condition I saw the gauge suddenly start to climb and got it shut down before the horn went off. I usually take a glance every few minutes at both the water pressure and temp gauges which are side-by-side on my console. I’ve found the modern BRP temp gauges and sending units to be pretty accurate by verifying engine temperature with an infrared temp gun.
