Home Forum Ask A Member WATERWITCH
  • #270285
    Roy Avvocato
      DOES ANYONE KNOW IF WATERWITCH FUEL TANKS FROM A MODEL  #571-10  AND A MODEL 571-20 ARE INTERCHANGEABLE THANK YOU, ROY  rabrooklyn@aol.com
      #270286
        They are not the same. The fittings for the fuel lines
        are at the front of the tanks on the twin. They are
        located about 1/4 of the way back on the singles.
        Also the twin has a bigger flywheel so the opening
        is about 7-1/4″. The opening for the flywheel on the
        single is about 6-3/4″.
