Home Forum Ask A Member Waterwitch rings
  • #232088
    melugin
      Fellow called wanting piston rings for a 1937 Waterwitch twin, 4hp, may be model 571-20. Anyone have dimensions for one, so I know what to look for? Or does some one have them?
      #232153
      kirkp
        My suggestion would be that once you are sure what motor you’re talking about, contact Peter Feldman who is the Waterwitch Special Interest Group Leader. He may be able to tell you what size ring is needed. Once you know that, I’d try Otto Rings. http://www.ringspacers.com/
        #232165
        melugin
          I have quite a few piston rings and can give this fellow some if I have the correct dimension. I’ll check with Peter.
