Home Forum Ask A Member Well, this wasn’t supposed to happen…
  • #9187
    nj-boatbuilder57
      Long story short, I had to disconnect the fuel line from the carb. Instead of the hose pulling off of the barb, the barb pulled out of the carb.
      What is supposed to hold the barb in? It almost looks like it was soldered…..but you can’t solder to an aluminum casting.
      Is the "factory insertion" supposed to be permanent? Stated differently: am I screwed?
      #70861
      jerry-ahrens
        i don’t think I’ve ever had that happen on one of those carbs.. is that lead on the end? You may be able to simply tap it back in.
        If nothing else, a little Marine Tex Epoxy on the outside will do the job. It works on my old Ford tractor anyway.
        #70862
        nj-boatbuilder57
          It does look like lead…..as if it had been soldered in.
          I don’t have any Marine Tex….but I do have JB Weld. I suspect that would work just as well. It claims to be gasoline proof once cured.
          #70863
            Locktite threadlocker
            #70875
            chinewalker
              Or try red Locktite. Good with metal on metal.
              #70877
              aquasonic
                I’ll take a drop or two of locktite any day over mixing up messy epoxy.
                Improvise-Adapt-Overcome
                #70879
                nj-boatbuilder57
                  Why? Ease of use or better capability of the Loctite product?
                  (I used JB Weld last night…)
                  #70883
                  squierka39
                    I think you’ll be fine with the JB weld. It won’t come apart now and if you got it all around it shouldn’t leak. I probably would have used the same thing.
                    #70888
                    bob-d
                      I haven’t had good results with JB Weld and gas. Tried to put the drain screen on the pickup tube back on a fifties OMC tank and it did not hold. Cleaned it well before application with a wire wheel, and brake cleaner.
                      Just my experience.
                      Bob D
                      #70893
                      nj-boatbuilder57
                        So how are these fuel barbs supposed to be held in place?
