Home Forum Ask A Member What about this one? Johnson 10 hp
  • #5680
    paulfromyork
      http://www.ebay.com/itm/152288690852?_t … EBIDX%3AIT
      So this one is near the head waters of the Chesapeake Bay. 1963. I could be there in two hours. I would offer $50.00, conditional on a first hand look. It MAY be salt water dead.(?)
      What goes wrong with salt water. I had a neighbor who fished the Bay, and would always run his outboard in a barrel of fresh water after returning home.
      Might this motor be worth a look, or should I forget it? Thank you.
      #47345
      PugetSoundBoater
        The seller doesn’t know anything about the motor,or is claiming ignorance .Not a good sign . Really can’t know until you drive out and take a look at it. Shifter seized could be expensive , it may be the gear case is junk, definetly check the lower unit gear oil
        Robbie Robertson
        #47349
          $120 seems pricy to me especially a potential salty . IF Compression is decent $50 ain’t so bad
          I have paid $25 CDN for a good 15hp FD and $50 for a nice 9.5hp mdl 9623 most JW’s (3) $50 and below CD & AD below 60$
          parts have always exceeded purchase prices but all came out to be good engines for less than $150
          all engines have cost less than a visit to the local Casino 😯 or my wife year’s supply of cat food to feed the strays
          that visit us every day 😆 .
          #47352
          2fast4me
            I’ve got a few QD’s with worn clutch dogs everything else is OK. Clutch dogs are expensive if they are available.
            2Fast4Me
            #47361
            Steve D
              quote pugetsoundboater:
              Shifter seized could be expensive , it may be the gear case is junk…
              I bought a ’56 Evinrude 10 HP a couple months ago with that problem. Shifter stuck, couldn’t pull the recoil. It’s from fresh water but lower unit looked crusty like it had sat in the water for a long time. I had a feeling it was stuck in the gear case, but the seller was a friend of my sister’s and assured me it did run good at one time. I really only wanted it for the powerhead so I took a chance. This is why it was stuck.
              print screen windows 7
              He was right about it running good though. I mounted the powerhead on my ’57 that needed one.
              https://www.flickr.com/photos/55515333@ … res/nL5Fq2
              screen capture
              #47369
              Doug Wilson
                I would say probaby worth a look 50 or 60
                Doug
                turned off?
                #47385
                  Well, the good news is that this later version of the 10hp powerhead has the larger wrist pins with needle bearings, so chances are good that the powerhead is serviceable. Needless to say, you would want to check the compression, although all the oil in the cylinders may give false high readings…The other good news is that it looks as though the gearcase has been replaced at some time though. Like others have said, you would definitely want to drain the gear lube, count on rebuilding/replacing the gearcase if you find it to be full of water. Good driveshafts for these engines are tough to find and the frozen shift lever is not a good sign.
                  The bad news is that this looks to be a salt water motor, so even the simplest of repairs might involve torch assistance.
                  All that being said, this would be the perfect size engine for you 12′ tinny though. So, I am in agreement with everyone, offer considerably less unless you confirm that gearlube is free of water and compression is good. And, be prepared for this to be a "parts motor".
                  I’m thinking you will find a better candidate for purchase at an AOMCI meet this winter. But, there is surely nothing to lose by having a look at this one if you don’t mind the drive.
                  #47388
                  paulfromyork
                    I sent a note saying $50,.00 tops, after a look/see. Reply: Not for sale at that price. (I deleted all the links)
                    #47399
                      I think you made the right decision….
                      #47400
                      1946zephyr
                        quote fleetwin:
                        All that being said, this would be the perfect size engine for you 12′ tinny though. So, I am in agreement with everyone, offer considerably less unless you confirm that gearlube is free of water and compression is good. And, be prepared for this to be a “parts motor”.
                        The powerheads got better, but the lower units are not near as good as the older 5 bolt.
