Home › Forum › Ask A Member › What am i into here?
- This topic has 20 replies, 9 voices, and was last updated 8 years, 9 months ago by
opposedtwin.
June 4, 2017 at 9:28 pm #7235
This is the magneto of my newly acquired FD-11. Looks like the woodruff key is sheared? Haven’t ever had a problem like this. How is the flywheel turning the crank shaft if the key is sheared? Because it is turning the crank.
The motor has no spark and so i was planning to test the coils, clean things up, etc.
Will i have to crack the case and go all the way down to remove the remains of the key? How should i proceed here?
Thanks,
ScottJune 4, 2017 at 10:03 pm #58985Yup sheared. Take the mag plate off. Should be able to get the remains of the key out then, and install new.
The key does not drive flywheel, the friction between the tapers does after torqueing to spec. The key simply aligns them, nothing else.
Should not be too bad a fix.
You likely did not have spark, since the flywheel had altered its orientation on the crank.
June 4, 2017 at 10:07 pm #58986Oh! Well that may be good news for the magneto then! Ok, took off the plate and the remains of the key came right out. Would dan gane have a new key? I’ll email him tomorrow.
Also, there are some very small scratches on the taper of the flywheel. Should i worry about them?
June 4, 2017 at 10:08 pm #58987Small scratches I would not worry about. You could dress them (valve grinding compound) to ensure a good seat.
June 4, 2017 at 10:39 pm #58988The underside of the ignition plate is pretty wet with oil, and the top side is a bit moist and dirty too. Likely i’ll be getting a chance to use that new seal puller i purchased from Richard about a month ago, eh?
June 4, 2017 at 11:41 pm #58989🙂
classicomctools@gmail.comJune 5, 2017 at 1:29 am #58999Just go down to your hardware store or auto supply and pick up a proper size key. Like Chris said, it’s not special and it doesn’t drive anything, only aligns the flywheel.
I had a running motor in once which had a piece of a nail aligning the flywheel instead of a Woodruff key. I don’t know for sure how long it had been in there but I bet it was quite a few years.
June 5, 2017 at 2:05 am #59002I had a key shear on a 35 HP RD two years ago. The hardware store keys that big were all too thick. I found a piece of scrap steel the right thickness and cut a chunk out of a corner with a hack saw, then held it with a pliers and shaped it on a bench grinder – worked fine! Yeah it was a bit of messing around, but I got it running without ordering and waiting for a part, and it’s still going strong.
DaveJune 5, 2017 at 2:50 am #59004Anonymous
Aren’t flywheel keys a softer metal than regular woodruff keys?
June 5, 2017 at 3:18 am #59007Flywheel keys rarely shear if the mating surfaces are clean, dry, fit together properly, and are properly torqued. In this case, since it did shear, I’d lap the crank taper to the flywheel. It only takes a few minutes, usually. The procedure is in Chrysler manuals.
