Home Forum Ask A Member What do the pins of the MOS tube, G, S, and D stand for?
  • #251942
      Which pin is the power connected to? Which pin is the control voltage connected to? Which pin is the output connected to?
      Are the enhancement and depletion pin connections the same?
      What do P and N types mean?
      What is the full name of the pin in English?
      #251946
        Huh? Is this an outboard question? I know just about enough about Field Effect Transistors to make me go dig out my old textbooks. Until then, I think D means Drain (output), and G means Gate. Maybe S means Source??? Subject to correction
        And P and N equate to PNP and NPN transistors. Somebody once said education is what you have left after you’ve forgotten everything you’ve learned. That describes me in this case.
        #252015
          http://www.hoivway.com/en/news/375.html
          google find
