Home Forum Ask A Member What is it?
  • #4246
      Seen this outboard online. What make and model is it?
      It appears to have a brass exhaust tube.
      Thanks.
      jasonh
        Mid 30’s Evinrude fisherman:
        http://library.mysticseaport.org/msca/e … =2004.55.2
        The one you have pictured is probably like a 34 or 35…the cylinders are not squared for front cover.
        #36284
          Thanks Jason!
          weedlessdrive
            Not too bad looking ! Did you get it? They clean up well.
            #36323
              The 1934 Fisherman had a curve at the bottom of the exhaust pipe. The ’35 has a straight pipe that goes to a outlet cast into the cavatation plate.
              #36324
                Weedless, I’m awaiting for a reply regarding it’s condition.
                Thanks for the nice photo Gary!
                  Seller says it’s "mostly there", "froze up", and he wants $75,
                  as the brass prop is worth that. I’ll pass……. I have enough
                  stuck outboards!
