Home Forum Ask A Member What to do with old stale gas?
Viewing 10 posts - 1 through 10 (of 21 total)
  • #8073
    amuller
      I have a few gallons of old fuel mix. Some I mixed last year at 24-1 and just never used, nor thought to put stabilizer in it. Some came with a purchased boat and is unknown as to age and mix–though it *should* be 50-1. Wondering about the best way to get rid of it. What do people think?
      #64034
      bkrsdoz
        I would get rid of the unknown boat gas through a recycle facility. I add some to used motor oil everytime I recycle it. Our city barn uses it to heat their building in the winter, and they take it free.
        The gas/oil that you mixed last year I would add to the fresh boat gas you are presently using a half a tank at a time to use it up.
        #64035
        PugetSoundBoater
          I take mine to the municipal garbage dump. There is a State/ Dept of Ecology program that takes gas and other hazardous items for free. They only except these items on certain days of the week.
          Robbie Robertson
          #64037
            I take mine to a friend that has a towing service and
            has waste oil furnaces in the shop.
            He said some gas mixed with all the oil in the
            tank is ok.
            Steve A W
            #64038
            jw-in-dixie
              Back when I was running 2 Farmalls they got the old fuel and loved it. Also left-over chainsaw fuel.
              #64039
              RICHARD A. WHITE
                Add 5 ounces of oil per gallon of unknown mix and go for a boat ride…
                The extra oil will ensure you have enough lubrication and you get to enjoy more water time…
                Seriously you can still run it, so …run it..
                classicomctools@gmail.com
                #64041
                George Emmanuel
                  I use it in my riding lawnmower and mix it with newer gas and it does fine.
                  George
                  #64042
                  JOSEPH BRINCAT
                    It works great for killing poison ivy.
                    #64045
                    A. Hoskins
                      To the best of my knowledge it is perfectly acceptable (environmentally) to pour it into a shallow pan and let it evaporate. I save it as "wash gas" and wash parts. I also burn stuff including papers I would otherwise shred. In rural areas, working around your property, you usually have a fire going. In suburban areas lots of folks have an "ambience" fire pit in the back yard. Ever tried to burn used motor oil ? Forget it. The stink will attract nosy neighbors.
                      Certified JB weld
                      #64049
                      20mercman
                        My 1986 3/4 ton 454 Suburban is a real dinosaur in that it has no catalytic converter or onboard ECM. This is also a rather thirsty machine. I run old gas through it in diluted form. Of course, not talking about phase separation ethanol gas failure, but a bit old, and it runs just fine. I do make sure I screen it through a coffee filter before use just to make sure I don’t dump a bunch of junk into my tank. It holds 40 gallons, so adding two gallons to a tank is not going to hurt a thing.
                        Steve
