Home Forum Ask A Member What type of grease
  • #4952
    justintime
      I have a JW-10 3 hp Johnson. I would like to lube the starter recoil and the throttle lever. I have taken all the grease out. Would I use a multi-purpose grease, Marine grease or Lithium spray lube. What would you use for these areas? Thank you for your support.
      #41845
        Nothing critical there. You probably have some multipurpose or marine lube on hand. Either is ok. Use just a thin smear on the magneto mounting rings. Any excess just gets thrown off and fouls the breaker points.
