Home Forum Ask A Member Where can I get a grommet for a 1960 Johnson 18
  • #268763
    huntleybill
      Does anyone make a repop grommet or have the NOS rubber for the carb face plate on the 1960 Johnson 18hp?  part number 307252. I can’t find anything anywhere.
      It is item #7 on the attached picture.
      378126-SHROUD-GROUP
      #268773
        Hm—m-m–m-
        nymarine.ca has 306101 for a 1959.  Wonder what the difference is????
        #268774
        labrador-guy
          Yup, North York Marine has them.   Click on parts for sale then on Grommets.
          http://www.nymarine.ca/index.html
          dale
          #268776
          huntleybill
            nymarine has the one for the 59, not for the 60. They are very different. I have already talked with Peter about this.
            Any other sources???
            #268786
              all  depends how original you want things to be…but
              if you are really stuck and can’t find any…. some   automotive  door edge trim products may be adapted or  some  fuel lines can be sliced  down the middle to snap over the edge
              see example :   check sizes,  prices  and styles on Amazon.. prices vary a a lot
              Edge Trim-Rubber U Channel Length 9.8FEET with self-Adhesive Design for car Doors, Table Corners, etc (9.8FEET, Black) : Amazon.ca: Tools & Home Improvement
              • This reply was modified 3 years, 4 months ago by JACQUES.
