Home Forum Ask A Member Where to get motor cover gasket
  • #227828
    todd281
      I am working on a 1973 Evinrude 4306 , four horse, outboard and would like to know where to get the gasket/ weatherstrip that goes under the fiberglass motor cover. [part # 206144] or something that would work in its stead. I looked at Mc-master but they will only sell in 25 foot lengths, I need about two. I am not sure what they have would be the right size and shape. Any ideas /pointers would be appreciated . Thanks
      #227835
        Did you look at NY Marine?
        http://nymarine.ca/cowlgaskets.htm
        todd281
          I did , rather pricy . I will keep looking
          #227864
            look into some automotive door trims maybe you can fit something on more cheaply…
            some use fuel hose and split it lenght wise then glue it on with a strong adhesive like GOOP
            https://www.amazon.ca/Black-Small-0-375-Height-0-039/dp/B00KG9BAY0/ref=sr_1_8?dchild=1&keywords=edge+trim+rubber&qid=1610797684&sr=8-8
            https://m.media-amazon.com/images/I/51+y+xFuenL._AC_UL320_.jpg
            etc… etc… on amazon
            • This reply was modified 5 years, 1 month ago by JACQUES.
            #227876
            olcah
              Also try an ad on classified here with a photo. Maybe someone will remove from a parts motor.
              #227884
              seakaye12
                As Crosbyman suggests….consider trying fuel line split lengthwise. I just did a 10HP Sportwin and used 3/16″ ID fuel line…..took a razor blade and cut it….and carefully pushed it on the lip. Worked VERY well. Certainly not “factry” but it sure serves it’s purpose in keeping the cowling from rattling around. A cheap fix until something better comes along?
                #227893
                Phil Budne
                  I’ve used auto engine vacuum hose split open.
                  http://www.omc-boats.org
                  #227919
                    I’m in the same boat, looking for the gasket for ’67 18 Evinrude. McMaster sells little sample packs of 4 or six pieces, for very cheap money. I bought a sample pack but nothing works for me, yet.
