Home Forum Ask A Member Which version of Gale built motor?
  • #305189
    nabmd
      I have this small motor which was a roadside find in Snowmass, CO. Single cylinder, probably 2.5 or 3 HP (seems bigger than 1.5HP), cast aluminum 2 piece tank, separate fuel shut off under the tank, (not integral with the carb), pressed steel carry handle (not cast aluminum), silver/aluminum paint without any recognizable decal, ID plate missing from front of transom clamp. The only stamped number on it is on the freeze plug on front of crankcase, behind carb, 0067217.
      #305194
        Compare it to photos of Sea Bee, or whatever Hiawatha’s model was named.
