Home Forum Ask A Member Will 1958 35 hp prop shaft work in Johnson 1955 25 hp RD-17??
  • #249826
    outboardnut
      Will Johnson RDS-20 1958 35 hp prop shaft work in 1955 25 hp RD-17??
      I know they have different part numbers but I was hoping the only difference is the threaded end versus no threaded end.
      Also-Is it a must to have a thrust washer with a plastic prop nut???
      The no threaded end prop shaft uses the plastic prop nut.
      Info:
      1958 35 hp prop shaft 305104/312867 (Has no threaded end)
      1955 25 hp prop shaft 302522 (threaded end)
      #249827
        I haven’t checked it out, but I think the dog splines are different (???) With that, they might be interchangeable if you replace enough other parts with it.
        The washer is there to prevent a spinning prop hub from knocking the nut off and losing the prop.
        #249854
        trex014
          I believe that all of the components from the 58 gear case will set in the 55 gear case. I know there’s is a difference in the clutch dog ears depth and then the gears for that dog, which gave the later design a longer life. Like frankr said, you’ll have to replace all the parts around it but it will work.
          #249872
          outboardnut
            ok thanks
