Home Forum Ask A Member Wisconsin, Model M RBM Connecting Rod Lubrication
  • #11380
      The subject motor I’m working on was partially disassembled when
      I got it. The piston and rod were "out", and the rod may have been
      previously removed from the piston, as the cotter key thru the piston
      and wrist pin had been removed.
      What I’m wondering is, what would be the correct orientation of the
      two oil holes in the connecting rod, "UP, or DOWN"???
      In case there’s no actual data for this particular motor, what’s
      the "norm" in general you’ve seen, or your best "theory" regarding
      your "UP or DOWN", where connecting rods are operated horizontal?
      Thanks!
      kees
        International Member
        always UP
        and the oil can work its way down for correct lubrication
        #83690
          Agreed. Think gravity.
          #83691
            Thanks, That was my thought as well, but I didn’t want
            to sway the jury in reaching a verdict! If I would have put
            the rod back on the piston like it was, and installed the piston
            in the cylinder with the "step" on the carb side, the oil holes would have been
            "Down", but it may have been apart a few times in the last 100
            years!
            Rod journal was not perfect, but at least "round".
            Way too much slop in the rod to crank fit, but
            I ground down the cap and rod mating surfaces
            a little, and seems satisfactory now.
            Still wondering what to do about the missing Elkhart magneto,
            so if anyone has suggestions, much appreciated.
