Home Forum Ask A Member Wisconsin RBM starting atempt to respond
  • #245404
      My response to you question has disappeared
      After trying to make an addition so I will try this.
      The ooze coming from the exhaust would
      seem to indicate to much fuel. When a motor
      wont start take out the plug an check to see if
      it is wet. If it is shake out the fuel or better yet
      blow it dry with air. Spin the motor over a
      dozen times or more with the plug out. Then
      put the plug back in and with the mixture screw
      closed all the way try to start the motor so it
      can clean itself out. To start a motor by bouncing
      it off compression you need to have the spark
      plug firing after TDC. As you spin the motor
      backwards the plug fires before the piston reaches
      TDC causing the motor to reverse direction and
      take off going forward. When your spinning it
      backwards the point that you releasing the knob
      is where you want the plug to fire.
      • This topic was modified 4 years, 6 months ago by Tubs.
      #245406
        My response to your question has disappeared
        after trying to make an addition so I will try this.
        • This reply was modified 4 years, 6 months ago by Tubs.
        #245424
          Tubs, Thanks! After I thought about what you said a bit, and drew myself a picture,
          it makes perfect sense. I’ll have to check my homemade timer to see if I have
          enough “retard” capability built in, then give it another “go”.
          Much appreciated!
            To find the point where you want the timer
            set at, spin the flywheel as if your trying to
            start the motor. Notice where you release
            the knob. Set the timer so you get the spark
            at this point. If the timer is set too far past
            TDC it wont have enough “kick” to get
            the motor spinning forward. You may feel
            it fire as your pulling the flywheel back. If
            not far enough past TDC there is no spark to
            start the motor. From time to time you want
            to be checking the plug to be sure your not
            flooded and spin the flywheel with the plug
            out to be sure you don’t have an over rich
            mixture till you learn the correct fuel and timer
            settings for starting.
