Home Forum Ask A Member Wizard fuel fitting questions
  • #6415
    opposedtwin
      Ok! I finally came across a wizard fuel fitting and now i need to refurb it (oh, and I should probably find a wizard too, huh?).
      Does it look complete from the pictures? I fished one o-ring out but it cracked. I assume it has atrophied over the years. Anybody know the correct size o-ring that’s required? Are both rings the same size?
      If Mercury made the wizard line, why is the wizard pressure fitting sooooo different from the Mercury pressure fitting? Just cuz Carl was a dyed in the wool slave to propriety?
      Thanks for any help!
        Hey, there had to be a difference somewhere, or it would be a Merc.
        #53539
        opposedtwin
          Frank, do you know if these come apart much like the OMC ones? I’m tempted to try and use your tool on it.
          Scott
          #53540
            My wild guess is that they probably will come apart, but I have no actual knowledge of that, or whether or not it will fit the tool. From the picture, it appears the inserts may be pretty well corroded in. Meaning they might be tough to get out. All guesswork.
            #53544
            brian-grigsby
              quote opposedtwin:
              Are the innerdz the same diameter as an omc? I have one of those too that I was wanting to redo. But I don’t have an OMC fitting for reference. Brian.
              #53550
              rjoynt
                Just out of curiosity, how do you know it is a Wizard fuel fitting? Just in case I come across one!
                #53562
                  they are a little bigger than OMC’s
                  #53563
                  opposedtwin
                    quote rjoynt:
                    I have seen them before on running wizard motors.
                    #53565
                    ian
                      That really looks like an omc fitting. I would expect/assume that it is assembled the same way.
                      I was just reading an article in an old copy of Antique Outboarder on the WA25 and how they installed thicker sleeves into the block to reduce hp and displacement. Carl wanted to sell motors anyway he could, but have the mercury’s the best.
                      Did they use this fitting for all the wizards? I have a WA25 that I am piecing together out of parts, and though that a Mark 30 fuel fitting might be correct.
                      #53568
                      PM T2
                        WA-25 uses the same style connector that the MK30 does. The fitting that is the topic of this post is for a pressure tank. WA-25’s and MK30’s both used fuel pumps (plural) and use identical fittings and hoses.
                        Hope this helps.
                        Best,
                        PM T2
