Wizard any tricks to getting the upper crankshaft seal out and new one in. Never done this before not quite sure where to start. Will be doing the lower crank seal too. Already replaced coils (cracked real bad) points and condensers, impeller, rebuilt carb and cleaning up the tank.
Thanks,
Doug
Doug
turned off?
\to0p seal can be pulled out by drilling a small hole in it and screw a screw in to pull on. bottom must be disassembled to replace the seal. just pull the lower end cap to access it.1 914 310 7086.
Thanks Dave thought that is what I had heard but wanted to make sure before i tear into that, last thing I need to do before starting it everything else is ready to go impeller broke up when I started to pull it out.
Doug
Doug
turned off?
