Home Forum Ask A Member worn out cam on a 5.5hp 1956-57
  • #212007
      can I “JB Aluminum weld ” the cam edge on a 5.5hp… it is worn badly just by rubbing against the cam follower on the carb.
      or should I just smooth it out with my dremel and install a 7/32 sleeve over the 3/16 cam follower ? hopefully a small stainless & .oiled 7/32 sleeve will rotate along the cam like a rubber roller does on other models
      the wear spot is so bad the cam follower jams as the cam rotates from start to high speed
      thanks for suggestions for a fix ( I know it would be best to replace the cam altogether )
      Joining AOMCI has priviledges ๐Ÿ™‚
      #212028
      ADAM GIBB
        I might have a cam for you. If you have a photo of your for me to match up, I can look.
        #212030
          Thanks Adam,
          it is at the cottage so I have to take it apart for a picture & i’ll recheck the engine mdl# to confirm ( bad memory ๐Ÿ™ )
          i’ll get back to you in a week or two (funerals, travel kids etc… tying up my free time ๐Ÿ™
          thanks
          #212193
            Don’t mess around with it, replace the worn cam…
