Home Forum Ask A Member Yacht , Duck, or Lightwin IDs
  • #193501
    todd281
      Is there a way to determine which of these motors you have using just the model or serial numbers? I am looking at a Ducktwin that has had some work done to it, and I suspect that it started life as a Lightwin,
      #193507
        The model number (first four numbers of the serial number) tells the tale) For instance, for the year 1965
        3502 is a Lightwin short shaft
        3503 is a Lightwin long shaft
        3512 is a Ducktwin (short shaft only)
        3532 is a Yachtwin short shaft
        3533 is a Yachtwin long shaft.
        Only Lightwins and Ducktwins had the weedless drive
        Yachtwins all had right angle drive.
        So what are your numbers?
        • This reply was modified 6 years, 1 month ago by frankr.
        #193523
        todd281
          This one reads 3512 on the tag . It has some blue paint on the lower, but maybe someone replaced those lower half parts. Thanks, once again, Frank. You are a amazing source of information .
