Home Forum Ask A Member Your thoughts on SeaFoam additive
  • #264022
    Matthew Pieklik
      I have a 20 year old craftsman lawn tractor. I put a whole can in the tank. I swear the kohler engine is running better than when it was new.
      #264087
      todd281
        I have been using it for a few years now. seems to help. I read a claim that it also helps stabilize ethanol fuel. I put it in all my small engines now just for that reason. So far, I have not seen any negative effects, and the fuel does seem to last longer.
        #264116
        labrador-guy
          Here is my two cents.  If you have a GM vechical with the 3.6 V six and you pop a check engine light PO24 code.  Variable cam sensor not responding.  It is caused by dirty oil and scum build up in the cam chain area.   The fix for me was a half can of sea foam in the oil.  Run the car 4-500 miles and change oil.   Light went out and has not come back on.  Now I am changing oil more often and have not had any check engine lights.   I think seafoam will help clean an engine internally!  JMHO!
          dale
          #264175
          ROBERT LAFAYETTE
            Good tip Dale,
            wife has 2015 Chevy
            Traverse with the 3.6 L v6
            we have not had that issue
            yet but change oil every
            5000 miles with GM
            Dexos oil at dealer. Car
            has 85,000 miles on it
            all we have done is
            front brakes so far!
