Home Forum Ask A Member Zephyr Questions
  • #201662
    kevinrude
      Hey Guys,
      I am in the process of tearing down a Zephyr parts motor. It has a bunch of broken parts and the motor was stuck.
      How do I remove the wrist pin from the connecting rod?
      Also, at the big end, the bolts connecting the rod to the cap have a slotted head. However, it looks like after installation metal was pressed in to the slots, presumably to keep them from loosening. How do I go about un-pressing this metal? Is it just heat and a screwdriver?
      I would like to save as many parts as possible in case I need them for my two other Zephyrs.
      As always, thanks!
      Regards,
      Kevin
      #201670
        Just turn the screw. It will shear off the upset metal. Put the screws in different holes when re-assembling so you have new metal to stake.
        #201826
        fastjohn
          I have Zephyr parts. PM me.
