Home Forum Ask A Member Float sink test
  • #247120
    elgin2
      When weighing down a float in liquid to see if it leaks,will water work or should it be gas?
      #247126
      dave-bernard
        water may not leak in. use gas.
        #247137
        Tom
          Just dip it in hot water. The heat will expand the air inside and you will see bubbles if it leaks.
          T
