Home › Forum › Ask A Member › 19?? Firestone 5 hp ID
- This topic has 8 replies, 5 voices, and was last updated 2 years, 10 months ago by
Buccaneer.
May 8, 2023 at 7:05 pm #276052
I thought I had a magic decoder ring to figure out Firestone
data plates, but if so, I can’t find it.
I’m guessing it’s close to 1950. Anyone know for sure what year?The facts…
19?? Firestone 5 hp
Stock # 10-A-73
Code # 133-3-1735
Serial # 1735-4924Also, I’m not finding a parts manual, surprisingly, as I went through a
very similar model a few years ago.
Anyone have a digital manual for this model?Prepare to be boarded!
May 8, 2023 at 9:37 pm #2760591735 = 1953
May 8, 2023 at 9:42 pm #276060May 8, 2023 at 9:53 pm #276061Firestones are Scott-Atwaters in disguise.
May 8, 2023 at 10:27 pm #276073Firestones are Scott-Atwaters in disguise.
Yes, and I went through my harddrive’s “Scott folder” and
didn’t find what I wanted either, lolPrepare to be boarded!
May 9, 2023 at 1:06 pm #276085Firestones are Scott-Atwaters in disguise.
Often “Last Year’s Models”.
May 9, 2023 at 5:31 pm #276095I used the leg & gearcase for a 3.5hp one lunger to make a “shift” motor. I think I still have it. Been iver a year since I’ve been in my storage, I’llness you know. Cool lightweight fishing motors. I used blood pressure cuff tubing to seal the shift shaft, They were a little short on gearcase seals, hope your gears arn’t rusty.If you ever install a driveshaft seal, to get to it heat the stainless impeller housing as it’s glued to the gearcase aluminum + removing the shif shaft guide ( aluminum tubr) there is an O-ring under for a shift shaft seal. A 53 7.6hp Firestone was my first motor over 35 years ago. Use red locktite on the three gearcase cover screws & watch for high spots around the threads. They pull out a little after years of tightening. Still have my 1947 Firestone 10hp. Weird driveshaft. twisted stock inside a guide tube.
May 9, 2023 at 9:05 pm #276104Buc- you can download the Scott manuals from our chapter website
May 9, 2023 at 9:44 pm #276106Jeff, I haven’t opened up the gear case yet, but did research a little about what impeller
to use. I’m hoping the gear and bearing are okay as well. One I worked on a few years
ago was a mess, and had to replace the Torrington needle bearing and the ball bearing.
Thanks.G Shnelzer, thanks! I’ll check out the link!
