Home › Forum › Ask A Member › 305098 Quad O-ring
- This topic has 7 replies, 4 voices, and was last updated 7 years, 8 months ago by
Buccaneer.
July 12, 2018 at 10:45 pm #10531
Is this the correct quad / square o-ring from McMaster Carr
to replace the overpriced omc 305098 ?https://www.mcmaster.com/#4061t236/=1dopob0
Square-Profile Oil-Resistant Buna-N O-Ring
1/8 Fractional Width, Dash Number 214Packs of 50
$6.94 per pack of 50
4061T236
Material Buna-N Rubber
Cross Section Shape Square
Dash Number 214
Fractional
Width 1/8
ID 1
OD 1 1/4
Actual
Width 0.139"
ID 0.984"
OD 1.262"
Hardness Durometer 70A (Medium)
For Use With Grease
Hydraulic Oils
Specifications Met ASTM D2000, SAE AS568, SAE J200
Temperature Range -30° to 212° F
Color Black
RoHS Compliant
The also have Quattro seals in the same size..
https://www.mcmaster.com/#90025k347/=1dopvnj
X-Profile Oil-Resistant Buna-N O-RingsAlso known as Quattro Seals and X-rings, these X-profile O-rings have four points of contact for a better seal in dynamic applications than round-profile O-rings. They also require less compression to make a seal, so they offer a longer service life. These O-rings are made of Buna-N, which is resilient and tear resistant. They resist motor oil.
Inch O-rings have a dash number and are sized to the SAE standard AS568.
For technical drawings and 3-D models, click on a part number.For technical drawings and 3-D models, click on a part number.
Inch
Fractional
Actual
Dash
Number ID OD ID OD Hardness Specifications Met Temperature
Range, °F Color Pkg.
Qty. Pkg.
Wd.: 1/8 Fractional (0.139" Actual)
214 1 1 1/4 0.984" 1.262" Durometer 70A (Medium) ASTM D2000, SAE AS568, SAE J200 -30° to 225° Black 25 90025K347 $5.83
========================Prepare to be boarded!
July 13, 2018 at 9:29 am #79474The OMC number doesn’t help me any until I know where it was supposed to be used….OMC’s use of a quad ring anywhere is not coming to my mind. Help me out here….
July 13, 2018 at 11:44 am #79479Yes, that’s it.
Bill, they are used in the Big Twin carbon seal. marineengine thinks they are worth $16.00 each.
July 13, 2018 at 12:27 pm #79480Frank, the first link showing a square o-ring say’s
it’s for "static" installations.
The second, named "Quattro" says for "dynamic"
installations.
Is the Quattro style the one I want????
Thanks.quote FrankR:Yes, that’s it.
Bill, they are used in the Big Twin carbon seal. marineengine thinks they are worth $16.00 each.Prepare to be boarded!
July 13, 2018 at 2:20 pm #79485Didn’t notice that. But the quattro (dynamic) one is the one you want. Notice the four sealing edges on it, which the "square" o-ring does not have.
"Static" means nothing moves. Think jar lids.
July 13, 2018 at 2:43 pm #79487Thanks for clarifying that Frank!
July 13, 2018 at 3:19 pm #79488Buc, if hou buy a bag and want to sell any, i’ll take 10. I’ll be at Tomahawk.
ScottJuly 13, 2018 at 4:30 pm #79497quote opposedtwin:Buc, if hou buy a bag and want to sell any, i’ll take 10. I’ll be at Tomahawk.
ScottScott, will let you know if I do.
Update- I ordered a bag of 25 of the Quattro seals.
Will let you know if they actually fit.
Also ordered some o-rings that I’m hoping will work
on the shift rod.Any guesses why OMC started using the square o-rings
in the carbon seals, but only on the bottom of the crankshaft?Prepare to be boarded!
