Home Forum Ask A Member 6.6 Chrysler
  • #5717
    melugin
      Just got a slick 6.6hp Chrysler model 601, serial number 2074. Original spark plugs never removed( till now), only minor scratches on cowl, etc. After a brief check of spark, lower unit lube and other vitals, it is a runner. Of course, I will change fuel lines and impeller before further running.
      What year is this motor? None of my books go this recent.
      #47614
      RICK EICHRODT
        Roger,
        I came across a 6.6 Chrysler but the serial number was 6018. If your serial number could end in 8, then according to my book, it is a 1968.
        Rick
        #47619
        b-dittmar
          Well the Chrysler 6.6hp was only made in 1968.
          you will probably find that the impeller is just fine they are usually like new.
          #47620
          melugin
            Thanks for the info. Confirmed that the model number is 601. My books only show the 6hp in ’66 and ’67, and I don’t have any newer literature. I’ll also install a newer fuel pump diaphragm before any cruising.
            #47621
            retiredoz
              It may not be a real orphan, that 10.2 cu in motor became a 7-hp in ’69 and ’70, and 8-hp after that till about ’78.
