Home Forum Ask A Member 8 Motors – $350 (anyone need parts?)
  • #281820
    John Gragg
      Thinking about heading to Bishop soon (probably next weekend) to pick up these 8 motors.
      The late owner’s son posted them on Facebook. I’m mostly interested in 1 or 2 of the Johnsons and perhaps the better looking Evinrude.
      He and I made a tentative deal, am I doing good or over my head? He had not made any claims about anything ‘running’, so I understand it’s a pig in a poke at this point.
      I’m not even sure what motors those Johnson’s are? Is that a TD20?
      Anyway – Comments?
      Does anyone have any need/interest in any parts you see here? The newer Johnsons and the better Evinrude I would expect would run with no problem, but who knows?
      I appreciate it. I would really like to help out anyone needing parts from these motors, I didn’t want to see them not go to good use.
      Let me know?
      Thanks!
      Best Regards,
      John Gragg
      RIverside, CA
      Just starting in the hobby, please be patient.
      48 Sea King 5hp GG9014A. Sold
      49 Sea King 5hp GG9014A
      48 Johnson TD20. Sold
      49 Johnson TD20. Sold
      54 Johnson QD15. Sold
      55 Johnson CD12. Sold
      57 Johnson RJE-19M
      57 Johnson RDE-19
      #281825
      John Gragg
        More Pics of individual motors
        John Gragg
        RIverside, CA
        57 Johnson RJE-19M
        57 Johnson RDE-19
        #281830
        John Gragg
          Last one
          John Gragg
          RIverside, CA
          57 Johnson RJE-19M
          57 Johnson RDE-19
          #281854
          labrador-guy
            Hi John,  those old motors will keep you busy for sure!   The 1954 Johnson 10hp is one of my favorites.  It has the sea horse embossed in the leg.  OMC only did that for two years 53 and 54.  That makes it special to me anyway!   I have both of those years of Johnson 10’s. and  they run just great!   If your are lucky maybe some of those motors won’t be stuck.   Stuck sucks for sure!
            dale
            get’em wet….don’t let’em set!
            #281864
            John Gragg
              dale
              Yep! I cant wait! The wife isn’t gonna be so happy tho’. I don’t yet have a plan on where they are all going to go! Including the 2 I already have, that’s 10 motors!
              I really hope they all are complete and that especially the Johnsons and the nicer Evinrudes start. No budget to restore them all, so I will have to pick one. I’m going to be smarter this time and get as many as I can running first, then let THEM tell me which one should return to showroom glory.
              Thx for the post.
              Best Regards,
              John Gragg
              RIverside, CA
              57 Johnson RJE-19M
              57 Johnson RDE-19
              #281886
                that  green 5.5 proved to be a chalenge for me  when the  GC shock absorber  got stretched.  I think it was damaged  it when I dropped it on the  cement floor  or… it was stretched before my purchase ???
                I eventually resorted to  tack welding the silly thing  at the recommended  6 in.11/16   otherwise  it would bind. and plagued my  reseal job.  now using a brass drive pin on the prop.
                #281916
                jeff-register
                  Reminds me of me when I was healther, all of a sudden O had  over 50 motors. Now just a few Mercurr’s. 58 22hp, KH7. KF5, 10hp Firestone 1851 & 57 6 cylindeer direct reversong Merc 1957 & a few more. I ended up buying a shrd to store them. Those are great motors!!
                  Good luck!!!
                  #281922
                    john… it is all relative… ever figured what cigarettes cost annually, golfing, casinos!! restaurants , pet grooming,  ….. dog/cat food & vets  alone will buy you an oldy per year.
                    #281940
                    labrador-guy
                      You did good on that shock absorber!  That spring cannot stretch.  If one end or the other slips the unit would not get longer.  A spring is an inclined plane.  When it breaks the coils ride up on each other causing the assembly to get longer.  I learned the hard way on the first one I worked on.  Pulled it down three times before I figured it out.  When it gets longer there is a good chance that the lower water pump housing will crack.  You will have a bugger of a time sealing that gear case.  I took a hammer to the shock absorber on my bench.  I wanted to see what was inside.  It is a simple device, one end of the spring is pressed into the top and the other end is pressed into the bottom.   I weld every one I work on now.   OMC did not expect these motors to last this long!
                      Couple things you may or not know about that 1954 10hp Johnson.  That is the first year for the clam shell hood.  The only Johnson to have silver wings on the hood.  Last year (until modern times) for the automatic reverse lock.  Last year for the four bolt lower unit.  One of the best runners I own!  The leg has been painted the hood is original.
                      dale
                      #282141
                      John Gragg
                        dale
                        The motors came home yesterday! 9 hour trip, back and forth.
                        Great news! All motors move, none seized. I tested the TD20, QD15 and CD12 for compression today. All are at, or slightly greater than, 90psi!
                        I don’t see any obvious abuse, they all seem to have been cared for fairly well. One might have had a little exposure to saltwater, bit we’ll see. Wish me (beginners) luck.
                        Best Regards,
                        John Gragg
                        RIverside, CA
                        57 Johnson RJE-19M
                        57 Johnson RDE-19
