Home Forum Ask A Member 89 Johnson 14spl M#VJ14RCEC
Viewing 3 posts - 21 through 23 (of 23 total)
  • #195509
      time to join up 🙂
      #195517
      Michael Anfossi
        International Member
        Heat. Heat the housing around the stud with a propane torch then try to move it.
        #195519
        Michael Anfossi
          Assuming the other bolts are out, can you twist the lower unit a little bit? Moving it back and forth 1/8 inch or so might help break the corrosion.
