Home Forum Ask A Member Advice/Help?
  • #241147
      Well, I found one – 1956 5.5 hp Evinrude. Wish me luck!!
      A good choice of motor to start with! The main thing to remember is it requires a 16:1 fuel mix using modern TCW III rated oil because of its mechanical design. Did it come with a two line pressure tank as these Fisherman models didn’t have fuel pumps?
      • This reply was modified 4 years, 8 months ago by Mumbles.
      #241148
      SWMCPA
        Thank you.
        #241152
        SWMCPA
          Thank you. I have been reading about the fuel/oil ratio. It did come with a two line pressure tank. It has six year old gas in it. First job will be to clean the tank and start with the new fuel, properly mixed. I won’t get to really start working on this until August. Between the Fourth
          Of July and visitors and visiting, July is taken up.
          #241153
            Well, you have made a good choice. These are great engines, many parts are still available new, and there are plenty of used parts around also. Ignition parts, carb kits, water pump, lower unit seals all available new.
            Yes, start with the tank…If it is rusted/badly fouled inside you may have to find another tank, they are around.
            You may get the engine started, but you will want to service all the systems completely if you want to make it a reliable daily runner.
            While the engine is sitting idle, you may want to drain the gear lube from it to inspect it…There are two large fill drain screws on the gearcase that both must be removed in order for it to drain completely. DO NOT remove that little phillips screw down there, that holds the shift linkage in place, it will fall out of place if the screw is removed….
            Gear lube from “back in the day” was usually a very dark color, which is normal…Newer gear lube will be gold in color.
            “milky colored” gear lube indicates water leakage into the gearcase
            Raw water mixed with gear lube is trouble also
            Things are in tough shape if there is no lube at all inside when you drain it…
            You may want to take a compression test also. These engines don’t have much compression, so reading between 70-80PSI on both cylinders is fairly normal.
            It is best to check these things out before investing alot of time/money in an engine that has internal damage.
            Feel free to post some pictures if that will help us help explain things to you….Don
            #241436
              The book CHEAP OUTBOARDS tackles the 5.5 and 7.5 hp nicely and has suggested an excellent read
              Has suggested by fleetwin before diving in to deep, do a compression test to see if it a viable adventure.
              lots of good utubes to help out to 🙂
