Home Forum Ask A Member Alumacraft floor
  • #194007
    Tinman
      Just tried out my model f over the weekend. Going to be a nice boat! My question is, its weeping a small amount of water upfront in the v and at the back seam at the transom on the floor. What is best used to seal these small leaks and what is best suited to paint the interior of the boat? The po painted it before but it is all flaking and coming off. Thanks.
      #194011
        if possible… add few inches water in the boat and check for precise leak sites front and back looking from the outside
        once leak spots identified apply corrective measures
        if rivited repunch / recrimp the accessible*rivets see if that helps
        if not apply sealants inside after the boat is dried out or try to weld
        * sometimes rivets are blinded by the keel if you have one dead center ….bummer
        you can always install a small bilge pump 🙂
        #194021
        stanley
          Captain Tolleys is my go to for all small leaks at seams or fastenings.I’ve used it on aluminum,wood and fiberglass boats with good success.It doesn’t take much and if used properly,is invisible.
          • This reply was modified 6 years ago by stanley.
          #194027
          reivertom
            Thanks for the head’s up…I was wondering the same thing as the OP.
            #194057
            Tinman
              Can it be painted over once applied? Looks like it might be my answer to my small leaks. And is there a paint durable enough to hold up on a floor without flaking off? Does any one ever use a liner for like a truck bed? Or Flex seal?
              #194097
              stanley
                If your asking about the Captain Tolleys,there is really nothing to paint over since it flows into the seam and you wipe the excess off.I’ve never had to paint over it ,but I’m sure you could.
                #194101
                Tinman
                  I want to paint the floor. It’s got several coats on now that are flaking off. Looks bad. I may try a bed liner. Not sure what would work best.
                  #194121
                    if it is anything like the aluminum boat I had … I ran a few stringer across the bottom between seats and screwed down a water proof ” porch ” plywood pre-painted a few coats of grey latex based exterior paint
                    installed a bilge pump under the back seat ….. keep my feet dry …..loved that rig e/w with a Classic 50 ….sold 15 years ago 🙂
                    • This reply was modified 6 years ago by JACQUES.
                    #194128
                    Samuel Phelps
                      This is usually the go to sealer . Gluvit.. http://marinetex.com/products/marine-tex-products/gluvit/
                      From what I have heard … It is a bit runny so you may have to tilt the boat to get it to flow where ya want it ..
                      #194138
                      gjonz
                        Permanent fix is west systems g-flex epoxy. It will wick into the void like solder using a torch.
                        Greg
