Home Forum Ask A Member Another Merc-o-tronic question
  • #193808
    mic57
      I just picked up a MOT 98 which has the battery negative wire just lying in the case disconnected. This is the unit with no circuit board and a vibrator. I was wondering if someone who has the same unit could look inside and tell me where the negative wire connects? I believe it connects to the pilot lamp but without a schematic would like to make sure.
      Thanks
      Mike
      #193809
        I would say yes since mine has a black and a green wire on the ground for the lamp.
        #193828
          #193885
          mic57
            Thank you both for your replies. This is exactly what I need. Now I just need to wait for the new power supply.
            Mike
            #193886
              I use a 7.2 volt battery from a rc toy and charger usually less than $30.00.
              #193928
