Home Forum Ask A Member Armature retaining ring #303278
  • #178779
    Newyota
      I ordered a NOS brass ring #303278 for my Skitwin.It has an oval hole in it and mine does not.Could not get all 4 holes to line up no mater how I tried.Part # is not different for this part so I figured no issue with the NOS one.I ended up elongating one hole to get last bolt in.No reason to suspect it will cause issue.Armature rotates and is positioned fine.
      #178838
        Why did you replace the original brass ring? In any event, I agree, elongating the hole is just fine, ring orientation is not an issue….
