Home Forum Ask A Member Best mix oil
  • #160456
    Ebooch
      Looking for a generic 2 stroke oil suggestion for my Elto Ace
      #160635
      lloyd
        Any common 2 cycle oil should be OK. Mix it with non ethanol gasoline at 16 to 1 .
        #160711
        fisherman6
          Use TCW-3 2-stroke oil for water cooled outboards. As Lloyd said, pretty much any commonly available brand of this type of oil will work fine.
          -Ben
          OldJohnnyRude on YouTube
          #160790
            If your motor is worn and hard to start from leaking crank seals or low compression, using a heavier aviation oil designed for air cooled motors may help. These oils are graded differently so a W80 aviation oil would be what we know as 40 weight, or SAE 40.
            https://www.shell.com/business-customers/aviation/aeroshell/piston-engine-oil/w80-w100-w120.html
            http://www.swaviator.com/html/issueja02/Hangar7802.html
            #160848
            PugetSoundBoater
              Mumbles- that is good info ,will keep that in my “research” folders.
              Thanks. Jim PSB
              Robbie Robertson
              #161271
              outbdnut2
                When your motor was new, it probably called for SAE-30 or SAE-40 Non-detergent oil. You can still buy that at auto parts stores.
